Ultrascale 100G ethernet implement error
I trying to from sample design to board design on Ultrascale 100G ethernet.
But implement error has occured.
------->error message is below
ERROR: [Place 30-415] IO Placement failed due to overutilization. This design contains 1103 I/O ports
180  while the target  device: xcvu190 package: flgb2104, contains only 1068 available user I/O. The target device has 1084 usable I/O pins of which 1    6 are already occupied by user-locked I/Os.
181  To rectify this issue:
182  1. Ensure you are targeting the correct device and package.  Select a larger device or different package if necessary.
183  2. Check the top-level ports of the design to ensure the correct number of ports are specified.
184  3. Consider design changes to reduce the number of I/Os necessary.
------->xdc file is below
###  (c) Copyright 2013 Xilinx, Inc. All rights reserved.
###  This file contains confidential and proprietary information
###  of Xilinx, Inc. and is protected under U.S. and
###  international copyright and other intellectual property
###  laws.
###  DISCLAIMER
###  This disclaimer is not a license and does not grant any
###  rights to the materials distributed herewith. Except as
###  otherwise provided in a valid license issued to you by
###  Xilinx, and to the maximum extent permitted by applicable
###  law: (1) THESE MATERIALS ARE MADE AVAILABLE "AS IS" AND
###  WITH ALL FAULTS, AND XILINX HEREBY DISCLAIMS ALL WARRANTIES
###  AND CONDITIONS, EXPRESS, IMPLIED, OR STATUTORY, INCLUDING
###  BUT NOT LIMITED TO WARRANTIES OF MERCHANTABILITY, NON-
###  INFRINGEMENT, OR FITNESS FOR ANY PARTICULAR PURPOSE; and
###  (2) Xilinx shall not be liable (whether in contract or tort,
###  including negligence, or under any other theory of
###  liability) for any loss or damage of any kind or nature
###  related to, arising under or in connection with these
###  materials, including for any direct, or any indirect,
###  special, incidental, or consequential loss or damage
###  (including loss of data, profits, goodwill, or any type of
###  loss or damage suffered as a result of any action brought
###  by a third party) even if such damage or loss was
###  reasonably foreseeable or Xilinx had been advised of the
###  possibility of the same.
###  CRITICAL APPLICATIONS
###  Xilinx products are not designed or intended to be fail-
###  safe, or for use in any application requiring fail-safe
###  performance, such as life-support or safety devices or
###  systems, Class III medical devices, nuclear facilities,
###  applications related to the deployment of airbags, or any
###  other applications that could lead to death, personal
###  injury, or severe property or environmental damage
###  (individually and collectively, "Critical
###  Applications"). Customer assumes the sole risk and
###  liability of any use of Xilinx products in Critical
###  Applications, subject only to applicable laws and
###  regulations governing limitations on product liability.
###  THIS COPYRIGHT NOTICE AND DISCLAIMER MUST BE RETAINED AS
###  PART OF THIS FILE AT ALL TIMES.
### CMAC example design-level XDC file
create_clock -period 10.000 [get_ports init_clk]
set_property IOSTANDARD LVCMOS18 [get_ports init_clk]
set_property PACKAGE_PIN D40  [ get_ports "sys_rst" ]
set_property IOSTANDARD LVCMOS12 [ get_ports "sys_rst" ]
### Transceiver Reference Clock Placement
### Transceivers should be adjacent to allow timing constraints to be met easily.
### Full details of available transceiver locations can be found in the appropriate
### Transceiver User Guide, or use the Transceiver Wizard.
### These are sample constraints, please use correct constraints for your device
### As per GT recommendation, gt_ref_clk should be connected to the middle quad
### Incase of VCU108-REV-1.0 Evaluation board with xcvu095-ffva2104-2-e device,
### if user selects CAUI10 GTY default gui configuration with CMAC core as CMAC_SITE_X0Y0
### and GT group X0Y4~X0Y13, the gt_ref_clk pin location is given below
### For other configuration / CMAC and GT locations, update the gt_ref_clk pin location accordingly
### and un-comment the below line
#set_property PACKAGE_PIN AK38 [get_ports gt_ref_clk_p]
### Change these IO constraints as per your board and device
### For better placement, please LOC the IO's in the same GT SLR region
### Below IO Loc XDC constraints are for VCU108-REV-1.0 Evaluation board
### with xcvu095-ffva2104-2-e-es2 device
### For init_clk input pin assignment, if single-ended clock is not available
### on the board, user has to instantiate IBUFDS in Example Design to convert
### the differential clock to single-ended clock and make the necessary changes
#set_property LOC AT19 [get_ports init_clk]
#set_property LOC AT18 [get_ports sys_reset]
#set_property LOC AP18 [get_ports send_continuous_pkts]
#set_property LOC AU17 [get_ports lbus_tx_rx_restart_in]
#set_property LOC AP20 [get_ports tx_done_led]
#set_property LOC AU21 [get_ports tx_busy_led]
#set_property LOC AN18 [get_ports rx_gt_locked_led]
#set_property LOC AN17 [get_ports rx_aligned_led]
#set_property LOC AN19 [get_ports rx_done_led]
#set_property LOC AP19 [get_ports rx_data_fail_led]
#set_property LOC AM16 [get_ports rx_busy_led]
set_property IOSTANDARD LVCMOS18 [get_ports sys_reset]
set_property IOSTANDARD LVCMOS18 [get_ports send_continuous_pkts]
set_property IOSTANDARD LVCMOS18 [get_ports lbus_tx_rx_restart_in]
set_property IOSTANDARD LVCMOS18 [get_ports tx_done_led]
set_property IOSTANDARD LVCMOS18 [get_ports tx_busy_led]
set_property IOSTANDARD LVCMOS18 [get_ports rx_gt_locked_led]
set_property IOSTANDARD LVCMOS18 [get_ports rx_aligned_led]
set_property IOSTANDARD LVCMOS18 [get_ports rx_done_led]
set_property IOSTANDARD LVCMOS18 [get_ports rx_data_fail_led]
set_property IOSTANDARD LVCMOS18 [get_ports rx_busy_led]
### Any other constraints can be added here
I attached verilog source.
Does anyone help me?
Teacher xilinxacct
Re: Ultrascale 100G ethernet implement error
@kyosuke.yoshizu
You have exceed your budget on the number of available ports... Try to reduce that usage (or implement on more capable hardware)
Please mark as solution accepted.
The 100G Ethernet core only requires a very small number of ports that connect to FPGA I/O pins.  There's the transceivers, the clocks, the small number of low speed I/O for the (e.g.) QSFP socket.  That's it.
I suspect you connected the LBUS ports of the IP to FPGA I/O pins, which adds roughly 1k pins.  These LBUS connections are meant to be terminated inside the FPGA fabric, typically by being connected to some other IP that generates or receives packets.
The cause turned out.
It is because one IP core was doubly defined in two logics.
