chintala
Using 1G/2.5G Ethernet PCS/PMA as SGMII to GMII Bridge on KC705 board
I want to use "1G/2.5G Ethernet PCS/PMA" IP core as "SGMII to GMII Bridge" on KC705 board.
The scenario is like this
MAC <=> SGMII-GMII bridge <=> CPRI [PHY] <=> SFP <=> optical fiber
What should be the configuration of the core?
Even if you dont know the exact answer, please help me in whatever way you can.
kgadde
Hi @chintala
Can you please clarify whether the MAC in your design flow is from Xilinx or is it your custom IP.
chintala
It is not from Xilinx. It sits outside the FPGA and communicates through SGMII interface.
guozhenp
Just generate 1G PCSPMA IP core with the interface "GMII" selected?
chintala
I am not able to see that option when configuring the 1G/2.5G PCS,PMA or SGMI core.
How to generate with GMII interface?
guozhenp
Sorry, I mistook it.
SGMII IP core just use the GMII interface.
ghasemi_r
when you choose SGMII, a bridge will be generated
and there is not GMII interface in this IP core, GMII is on tri_mode_ethernet IP CORE
