rajuponnaganti
Voyager
Voyager
Validating QSGMII IP
We have two KC705 boards.We want to test QSGMII before going using this IP.In datasheet, mentioned as in pic.Where can we find tested design files? How did you test this IP? what is the mode of operation?
Thanks in advance
waiting for response....
yenigal
The core was tested with internal design and in SMA/SFP loopback.
 You can just use the example design for basic link up and for data transmission you can integrate the TEMAC example designs to the 4 ports and test it.
Satish
rajuponnaganti
Voyager
Voyager
With external PHY , it is not working.You should check with External PHY and share the design.It will be helpful for users.
ponnagantiraju
Ok the problem seems to be fixed.
