nanz
Versal Ethernet
Versal Ethernet
This post will cover all necessary information you should know before starting to build Ethernet designs on Versal ACAP devices.
Design Flow
Before starting any Versal designs, users are highly recommended to go through Versal System and Solution Planning.
In general, there are two basic design flows to use when targeting Versal ACAP, ie, Vitis Environment Design Flow and Vivado Tools Design Flow. Vivado IP Integrator is the primary flow for non-AI Engine-based projects, and is recommended to use for Ethernet designs creation targeting Versal
Please refer to UG1273 Chapter 4 – “Design Flow” for more detailed information.
For all PL Ethernet IPs, transceivers IPs (GTs) are separated completely. Use Block Automation within IP Integrator for Ethernet IP to GT integration. Please refer to PG331 Chapter 4 - “Xilinx IP - GT Quad Integration” for more details.  All designs require the CIPS IP, which contains the PMC used to boot the device. For more information, see the Control Interface and Processing System IP Product Guide (PG352).
For PS GEMs, they are sitting inside CIPS. Please refer to PG352 for CIPS product guide.
IP Product Guides and Master ARs
Here is a list of the Ethernet IPs with their product guides and release notes and known issues master ARs:
IPs
Product Guides
Master ARs
PS-GEM (Versal ACAP TRM)
AM011
(Xilinx Answer 75828)
GEM registers (Versal ACAP TRM Register Reference)
AM012
Multirate Ethernet MAC (MRMAC)
PG314
(Xilinx Answer 75817)
600G Channelized Multirate Ethernet Subsystem (DCMAC)
DS950
PG369 (See Versal Premium Lounge)
Coming soon
600G Interlaken with FEC
DS950
PG371 (See Versal Premium Lounge)
Coming soon
400G High-Speed Crypto (HSC) Engine
DS950
PG372 (See Versal Premium Lounge)
Coming soon
400G RSFEC
PG378 (See 400G RSFEC Lounge )
(Xilinx Answer 73658)
For rest of soft Ethernet IPs supported on Versal, please refer to the master release notes and known issue. The list is provided in Ethernet Useful Resources sticky note.
Ethernet Drivers
The wiki pages document the support features and known issues, and drivers can be found on github.
Wiki
GitHub (drivers)
PS-GEM
Standalone EMACPS
emacps driver
Linux MACB
macb driver
1G/10G/25G
Standalone AXI Ethernet
(Please note: 25G is not supported in standalone driver)
axiethernet standalone driver
Linux AXI Ethernet
axiethernet linux driver
Example Designs and Blogs
Lounges
Here are the documentation lounge links:
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
