01-30-2013 10:41 PM
I am using an xps_uartlite IP Peripheral(1.02.a) for Uart Communication. I have set the baud rate in the EDK as 9600. But when i check the data at the receiving end , i am able to receive it only at half the baud rate as the transmitter side (i.e. 9600/2 = 4800). I have varied the baud rates and the above applies to all. I tried probing the TX Port on the FPGA through Chipscope debug peripheral and i ensured myself that the data coming out was at the set baud rate.
i am using a Spartan 3a-DSP with 50 Mhz Clock.
Is this a known issue. Please assist me with this as early as possible.
06-05-2017 07:56 AM
I'm getting a similar issue, and it also affects UART16550. I suspect it's an FSBL issue, but I can't boot from any that I generate.
06-12-2017 08:09 AM
