venkatakrishs
Xilinx Emaclite Driver in Polled mode.
I am on to enable ethernet in ARTY A7-100T board for a custom SoC with Linux 5.5.0-rc1. I would like to know if we can use Xilinx AXI Emaclite in Polled mode instead of interrupt driven mode.
Thanks in advance
Tags (2)
nanz
Hi @venkatakrishs ,
The polled more isn't supported in the driver.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
nanz
Hi @venkatakrishs ,
