amitg
ZCU102 MGT-refclk for user SMA transceiver
I'm using ZCU102 evaluation board and I'm using Aurora IP with the SMA user transceiver from quad 128.
I don't know  which MGT refclk I need to take and what the frequency of this MGT-refclk because they are both for the HDMI (that I don't  use at all).
Thanks for the help.
venkata
You can use the following as input to Aurora IP.
MGTREFCLK0 - HDMI_SI5324_OUT_C_P/N
The frequency of the refclk is based on the settings you chose in the IP GUI. The frequency of this input can be programmed manually.
