Observer ian@lang
Zynq/GMII2RGMII not recognised
I have been trying for some considerable time to get this Gigabit Ethernet module - http://www.knowres.ch/products/kr-lan-a1/ - connected to this Zynq board - http://www.knowres.ch/products/krm-3z030-768/ - via this carrier - http://www.knowres.ch/products/krc3600-carrier-kit-2/ working but without success, so I've decided to try to get help on this forum.
My Zynq system is as follows:
I am using both Ethernets on the Zynq, the first via MIO and the second, the problematic one, via EMIO.  The second PHY reset is controllable from an AXI writeable register which also generates a low going pulse automatically after power up. The gmii_to_rgmii IP is configured thus:
I can confirm the presence of the two PHYs over the mdio from u-boot:
Zynq> mdio list
eth0:
0 - Marvell 88E1518 <--> ethernet@e000b000
eth1:
7 - Marvell 88E1118R <--> ethernet@e000c000
And I can write to the register in the gmii to rgmii:
Zynq> mii device eth1
Zynq> mii read 0xa 10
0000
Zynq> mii write 0xa 10 0x0040
0040
I've tried many variations of device tree, system-user.dtsi, and here is my current best effort:
&gem1 {
       phy-handle = <&phy1>;
       gmii2rgmii-phy-handle = <&gmiitorgmii>;
       phy-mode = "rgmii-rxid";
       status = "okay";
       xlnx,has-mdio = <0x1>;
       ps7_ethernet_1_mdio: mdio {
                                 phy1: phy@7 {
                                             compatible = "marvell,88e1118r";
                                             device_type = "ethernet-phy";
                                             reg = <7>;
                                 gmiitorgmii: gmiitorgmii@10 {
                                             compatible = "xlnx,gmii-to-rgmii-4.0";
                                             reg = <10>;
In u-boot I see:
Net:   ZYNQ GEM: e000b000, phyaddr ffffffff, interface rgmii-id
eth0: ethernet@e000b000ZYNQ GEM: e000c000, phyaddr 7, interface rgmii-rxid
Warning: ethernet@e000c000 (eth1) using random MAC address - 06:94:9d:e4:74:ca
, eth1: ethernet@e000c000
U-BOOT for os
ethernet@e000b000 Waiting for PHY auto negotiation to complete...... done
And then:
Marvell 88E1510 e000b000.ethernet-ffffffff:00: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=e000b000.ethernet-ffffffff:00, irq=POLL)
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 28 (00:0a:35:00:22:01)
libphy: MACB_mii_bus: probed
xgmiitorgmii e000c000.ethernet-ffffffff:0a: Couldn't find phydev
macb: probe of e000c000.ethernet failed with error -16
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
So it appears that the gmii to rgmii is not getting initialised and this is indeed confirmed when I try to ping from u-boot.  However, if I write to the register inside the gmii to rgmii, ping comes to life:
Zynq> ping 192.168.0.143
Using ethernet@e000c000 device
Abort
ping failed; host 192.168.0.143 is not alive
Zynq>
host 192.168.0.143 is alive
However, upon booting to Linux, even after writing this register, I see no sign of eth1:
root@os:~# ifconfig
eth0      Link encap:Ethernet  HWaddr 00:0A:35:00:22:01
          inet addr:192.168.0.59  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: 2a02:8388:6901:c300:20a:35ff:fe00:2201/64 Scope:Global
          inet6 addr: fe80::20a:35ff:fe00:2201/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:5 errors:0 dropped:0 overruns:0 frame:0
          TX packets:22 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1456 (1.4 KiB)  TX bytes:3316 (3.2 KiB)
          Interrupt:28 Base address:0xb000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
root@os:~#
So I think I really am very close to getting the second ethernet running.  However, I've been struggling with it for a considerable time now and I'm beginning to run out of ideas.  Som I'm really hoping that somebody can suggest a way forwards.
Observer ian@lang
Re: Zynq/GMII2RGMII not recognised
I received no replies to this thread, which is why I re-worded and re-posted the thread here:  https://forums.xilinx.com/t5/Ethernet/Gmii-to-Rgmii-driver/m-p/1041756/highlight/false#M17305.  However, if you find yourself here with the same problem I had, please follow the link, where you might find something more helpful.
Ian Lang
Observer ian@lang
Ian Lang
