info related to Clock connection between 1G PCS/PMA SGMII IP Core and MAC
Hi all,
i am presently trying to interface custom MAC to PCS/PMA IP core, i am using VCU118 kit i have few doubts can anyone please clarify.
PCS/PMA ip core is configured as 1G, SGMII,  drp clk = 50.0, reference clock, transceiver refference clk = 125 mhz,
Rx GMII clk src=RXOUTCLK. Device specific Transceiver.
i have to connect the following clocks to the MAC.
         clk_mac_tx   ( should be 125MHz for gigabit operation
                                                 25MHz for 100M operation
                                                 2.5MHz for 10M operation)
         clk_mac_rx ( should be 125MHz for gigabit operation
         clk_mac_gtx   (should be 125 mhz fixed)
please find attached clocks comming out from the core
in my design i have given like this
assign clk_mac_tx  = sgmii_clk_r;
assign clk_mac_rx = sgmii_rx_clk_r;
assign clk_mac_gtx = userclk2_out;
am i doing any mistake ?? please let me know
Re: info related to Clock connection between 1G PCS/PMA SGMII IP Core and MAC
Hi @mdakram140,
The best example/reference you can find is to generate the AXI Ethernet Subsystem IP for VCU118, which has the SGMII and MAC underneath.
"Don't forget to reply, kudo and accept as solution."
the eample design has sgmii core with lvds interface but i am using sgmii core as gmii to sgmii converter .
should i choose RXOUTCLK or TXOUTCLOCK in GUI ??
