BG
ksz9131RNX pl ethernet does not work on lwip echo server example
I use ksz9131RNX chip for PL ethernet on board.  I designed pl part and sdk. I run echo server example. But it not work.
In SDK terminal ;
TCP packets sent to port 6001 will be echoed back
auto-negotiated link speed: 100
Error set buf addr 1255D6 with 4 and 3, 2
Ethernet Link down
DHCP Timeout
Configuring default IP of 192.168.1.10
Board IP: 192.168.1.10
Netmask : 255.255.255.0
Gateway : 192.168.1.1
TCP echo server started @ port 7
I saw these message.
shabbirk
Hi @BG
By default in LWIP sources, you dont find the ksz9131RNX PHY support. You will have to add it. Here is some reference to do the same:
https://forums.xilinx.com/t5/Ethernet/Failure-to-initialize-Microchip-PHY-in-lwIp-echo-server-example/td-p/1049969
https://www.xilinx.com/support/answers/63495.html
Shabbir
BG
I can not read PHY address. I can not connect with MDIO I suggested eth1.PNGeth2.PNG
PL ethernet I created MDIO block...
