jcwill585
lwip echo server keeps getting "out of memory error" when sending a lot of packets
I'm not sure why my project keeps getting "out of memory error"
err = tcp_write(pcb, payload, len, 1);
Err will equal -1.  What setting should I change?
shabbirk
Hi @jcwill585
See if this forum thread helps, that also discusses the same error with the high load
https://forums.xilinx.com/t5/Ethernet/ERR-MEM-on-tcp-write-from-a-corrupt-memory-table-standalone-BSP/m-p/1141250
Best Regards
Shabbir
