transfer text file from pc to fpga
Hi all,
I use the kcu105 eb, and the axi ethernet subsystem ip.
I was able to connect the fpga to the pc via lan and send packets from packet builder to the fpga and see the transfer in wire shark.
I make a loop so I saw to packets in wire shark.
Now I want to send a text file from the pc to the fpga and with the loop to get the file back to the pc,
I need some help, some one know how to do it? or some tool?
thanks,
Patolsky
