Surya_ks
Hello
[Common 17-69] Command failed: This design contains one or more cells for which bitstream generation is not permitted:
design_1_i/xxv_ethernet_0/inst/i_design_1_xxv_ethernet_0_0_top_0/i_design_1_xxv_ethernet_0_0_CORE (<encrypted cellview>)
If a new IP Core license was added, in order for the new license to be picked up, the current netlist needs to be updated by resetting and re-generating the IP output products before bitstream generation.
getting this error while using the 10 g ip , i have doubt this is license  error can you help me any to correct this error.
i will attach my license snapshot
Thank you.
Tags (2)
nanz
Hi @Surya_ks ,
It looks like you have the design linking license for x_eth_mac, xxv_eth_mac_pcs; and the design linking license does not allow bitstream generation. You will need to get HW_Evaluation license for it. basekr is not relevant as you are not using this mode.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
nanz
Hi @Surya_ks ,
I am not able to see the picture clearly. If you have HardEval license, you should be able to generate bitstream but it will only work a certain period of time.
If you are using BASE-KR, this requires a full purchased license to generate a bitstream.
If you are sure you are having a valid license, have you done a reset/re-generate output products so the license can be picked up correctly? Can you share the screenshot when you right click on the IP in IP Catalouge and click on "check license status"?
Surya_ks
Hello
I give the  clear snapshot of license  can you check this is valid or not , and i using the BASE-R in 10G ethernet subsystem ip ,i checked the status of ip it's showing like not purchased yet ,that snapshot also given below can you check that also , please help me to find out the solution .
Thank you.
Surya_ks
Hello
I share the ip license information please go through this and give reply as soon as possible.
Thank you
nanz
Hi @Surya_ks ,
Surya_ks
Hello
How will get the HW_Evaluvation license . Can you tell me that.
Thankyou
nanz
Hi @Surya_ks ,
Please go to this page:
https://www.xilinx.com/products/intellectual-property/ef-di-25gemac.html
And you can click on the Evaluation page.
