Observer bwerth
xapp 1306 top module designation
Hi Everyone,
I've been trying to implement the xapp 1306 pl 1g ethernet reference design, but when I try to compile the project in IDE, it asks for a top module and complains that there aren't any modules in the design. Has anyone else run into this issue with this reference design or application note? Thanks for any help.
Re: xapp 1306 top module designation
Does it have a block design (IP integrator)?
If it does, you have to make and HDL wrapper for the block design.
Avi Chami MSc
FPGA Site
Avi Chami MSc
FPGA Site
Are you following the steps mentioned in below link as is to implement the design
http://www.wiki.xilinx.com/PS+and+PL+based+Ethernet+in+Zynq+MPSoC
Satish
Observer bwerth
   That ended up working, thank you for the comment.
