01-22-2020 06:38 AM
I'm trying to use the 10G ethernet subsystem, but I have a critical warning during the implementation:
CRITICAL WARNING: [Vivado 12-1411] Cannot set LOC property of ports, Could not find a valid bel for the shape with the following elements: design_1_i/design_1_i/xxv_ethernet_0/inst/IBUFDS_GTE4_GTREFCLK0_INST user_si570_sysclk_clk_n user_si570_sysclk_clk_p CRITICAL WARNING: [Vivado 12-1411] Cannot set LOC property of ports, Could not find a valid bel for the shape with the following elements: design_1_i/design_1_i/xxv_ethernet_0/inst/IBUFDS_GTE4_GTREFCLK0_INST user_si570_sysclk_clk_n user_si570_sysclk_clk_p
I don't know how to solve it.
01-22-2020 11:36 PM
Solved selecting custom gt_ref_clk in the eth subsystem IP
01-22-2020 09:45 AM
Hey andrea@ross,
What constraints have you applied to those ports, is there anything in your constraints file? And which part are you targetting? You might try checking or replacing the pins.
Did you start with the IP Example Design?
01-22-2020 11:36 PM
