Observer olkhramus
About Petalinux u-boot.elf and bl31.elf files
Do Petalinux u-boot.elf and bl31.elf  files depend from board ( for example ZCU102 and my custom board with the same FPGA chip as ZCU102)?
Re: About Petalinux u-boot.elf and bl31.elf files
Hi @olkhramus
No they should work on multiple boards. The FSBL will change depending on the board
Florent
Observer olkhramus
If I understood correctly for my custom board based on XCZU3EG chip I can use the u-boot.elf from
ZCU102 board ( UG1209) ? Is that correct?
Yes you should be able to use it
Florent
