Analog stimulus file
 am working in real time signal processing. How to give analog signal in real time, without giving analog stimulus file in the form of text/ csv file to Vp & Vn pin or any auxillary pins.
Re: Analog stimulus file
Hi revathiinokawalab123,
Which Evaluation Board are you using? You could use a DAC output connected to the input pins.
Andres
Hi andresb san,
Thankyou for your kind reply. Am working in zynq zc702.
(You mean From AMS 101 evaluation card ) You could use a DAC output connected to the input pins.
If possible quote me some user guide for enabling my AMS with XADC in zynq.
I will attach my block design and experimental set up. kinldy go through it. In my design i have used Vp and Vn as input port in xadc wizard, Where it will get its input actually, my target is i need to apply analog input to that pin, is it possible. If you give some basic idea, it will be useful to me to proceed
