Configuring DDR-MT41J256M8DA-125:K on custom board based on ZC7Z045
We are designing a custom board (design based on ZC706) using DDR- MT41J256M8DA-125:K
Since Vivado doesn't support our DDR part no , we are selecting the option "User Input" as per the below pic.
To configure DDR using Vivado since our custom board DDR- MT41J256M8DA-125:K is not supported by Vivado following parameters are needed
    (1) Length (mm) ==> As per our understanding https://www.xilinx.com/support/answers/46778.html that this value is fixed for a given Zynq SOC.
   (2) Package Delay(ps)
   (3) Propagation delay(ps/inch)
From PCB design we got the propagation delay (in MILS) for the following signals:
DDR_ADDR
PS_DDR3_CLK_N
PS_DDR3_CLK_P
PS_DDR3_A0
PS_DDR3_A1
PS_DDR3_A2
PS_DDR3_A3
PS_DDR3_A4
PS_DDR3_A4
PS_DDR3_A5
PS_DDR3_A6
PS_DDR3_A7
PS_DDR3_A8
PS_DDR3_A9
PS_DDR3_A10
PS_DDR3_A11
PS_DDR3_A12
PS_DDR3_A13
PS_DDR3_A14
PS_DDR3_BA0
PS_DDR3_BA1
PS_DDR3_BA2
PS_DDR3_CAS_B
PS_DDR3_CKE
PS_DDR3_CS_B
PS_DDR3_ODT
PS_DDR3_RAS_B
PS_DDR3_RESET_B
PS_DDR3_WE_B
From the above parameters, kindly request some inputs on how to calibrate our DDR.
Asmaitha
Re: Configuring DDR-MT41J256M8DA-125:K on custom board based on ZC7Z045
Hello soujanya.kothamasu@asmaitha.com,
The Length attribute is the average trace length on the PCBA for that signal group.
The Package Delay attribute comes from the selected Zynq device. If the table isn't automatically populated then you can get the pin propagation times by opening a synthesized design and in either the IO Ports or Package Pins view right click in the area, select "Export I/O Ports", select CSV, and then press OK.  When you open the CSV file you'll see the PS memory interface pins in the "Site Type" column starting with "PS_".
The propagation delay (ps/in) is derived from your board stackup.  If you have it in ps/in then you can convert to mils by dividing the ps/in value by 1000 since there are 1000 mils in an inch.
Did you succeed configuring the MT41J256M8DA?
Alexandre
