Visitor angelmaya
Coolrunner-II CPLD - Files to reflash the Atmel USB controller
Hello Xilinx community,
The recoginition of a XC2C256 device through an USB port has failed. When doing a boundary scan, iMPACT says it doesn't find any device, so its console displays a "check cable setup" message. So far, I have managed to program it successfully using a JTAG connection (Xilinx Cable Platform, model DLC9LP). However, I hope to use the USB port again, like this application report may suggest:
https://www.xilinx.com/support/answers/44512.html
The utility program asks for a data EEPROM file and another file to program the flash memory.
I would like to receive these files if you have them.
Thank you for your attention
Visitor angelmaya
Re: Coolrunner-II CPLD - Files to reflash the Atmel USB controller
Almost a year later, I was able to reprogram sucessfully the AT90USB162 interface from the Coolrunner-II board. However, that didn't work as expected. Still, IMPACT error 923 appears. I also followed advice given from this AR: https://www.xilinx.com/support/answers/44397.html. No good.
Then, a quick conclussion of my experience is that the board is damaged.
I think error 923 is linked to connecting the board to a computer with bad USB cables (e.g. chinese ones). I want to confirm this, when I have spare time to check.
