Visitor m.yaghmai
Could not find FPGA device on the board for connection 'local'. ( Hardware Manager - unconnected ) - KC705
I am using KC705 Evaluation board and I programmed this board 2-3 times using Platform Cable USB II through Vivado 2018.2 and Vivado 2016.2 on Windows 10 but all of a sudden when I open the hardware manager in Vivado Design Suite 2018.2 or 2016.2 , there is no hardware target open and when I use "Auto connect" it does not show the device ! ( Screen shot is attached)
What I have tried so far:
1. Platform Cable USB II Status light is green.
2. Checked Device manager to see if the driver needs an update or if it is still there. It seems Ok ( Screenshot is attached)
3. Changed the USB port that I connected the Platform Cable USB II to it just to make sure it is not because of the USB port. Did not help!
4. Used another Platform Cable USB II . Did not work!
5. Connected my KC705 Evaluation board to another PC with the same cable and it shows the FPGA!!!
6. Checked if in task manager, hw_server runs in the background or not from before. It was not!
I am not sure why it is working on another computer but not mine anymore !
Would you please help me with that ?
Thank you!
Visitor m.yaghmai
Re: Could not find FPGA device on the board for connection 'local'. ( Hardware Manager - unconnected ) - KC705
Hi m.yaghmai,
Have you tried connecting to the USB-JTAG port of the KC705 directly? All you need is a microUSB cable.
The other thing I'd try is disconnecting the USB-UART cable (the Silicon Labs CP210x line on the Device Manager) and see if that changes anything.
Let us know the results and we'll suggest other troubleshooting ideas.
Andres
Visitor m.yaghmai
