Visitor rampage
Error downloading executable program with JTAG
My board is Eaglego hd.
After I compiled the program (routine), I downloaded it to the board.
The steps are as follows:
1. Execute "program fpga" first
2.Right click on the application project-run as- launch on hardware
But there was an error in downloading the program.
ERROR : Memory write error at 0x100000. Cannot access DDR: the controller is held in reset
What is the reason for this mistake?
Visitor rampage
Re: Error downloading executable program with JTAG
@stephenm
I don't quite understand what you mean by reference design.
But I have solved this problem.
Refer to the following two websites:
Https://forums.xilinx.com/t5/Embedded-Development-Tools/Programming-Flash-DDR-hold-in-reset-error/td-p/419511
Https://blog.csdn.net/christne1225i/article/details/53382192
Conclusion:
The reason is that there is no run ps7_init.
Step: Click on Project in the middle - - - right-click - - - properties - - - select init file - - - check run ps7_init
Thank you for your answer!
Is there a reference design for this board that you can use?
Visitor rampage
@stephenm
Conclusion:
