Visitor th3frankxd
First FPGA board
I'm looking for a board to get started with FPGA's and circuits.
Im looking for a allround board, something I can use as a microcontroller, but also for more advanced stuff like ray tracing accaleration and soft cores like risc-v.
I'm mostly looking at the Artix 7 100T and the ZYNQ 7020.
Ideally I would like a minimal board with only the FPGA, qspi flash, uart, jtag and dram (and other essential stuff I might have missed) and attach this board to a custom pcb with the peripherals I need.
Kinda like this CMOD A7 (but with a bigger FPGA and DRAM) https://store.digilentinc.com/cmod-a7-breadboardable-artix-7-fpga-module/
I really dont want to exceed the 200 euro.
So far i found these 3 boards (between 140-170 euro)
MYIR Z-TURN with I/O board
http://www.myirtech.com/list.asp?id=502
PYNQ-Z1 (which is as far as I can see basically a Arty-Z7 but cheaper)
https://store.digilentinc.com/pynq-z1-python-productivity-for-zynq-7000-arm-fpga-soc/
TE0725 with a Artix 100T
https://shop.trenz-electronic.de/en/TE0725-03-100-2C-FPGA-Module-with-Xilinx-Artix-7-XC7A100T-2CSG324C-2-x-50-Pin-with-2.54-mm-pitch?c=148
How hard is it to add external DRAM do the TE0725?
The specifications of the TE0725 mentions a system clock of 100mhz, the ARTY A7's mentions a clock speed exceeding 450mhz. Whats the deal with this?
For the Z-TURN and TE0725 I will need a JTAG programmer.
Would this one suffice? and what are the limitations compared to a official one?
https://www.aliexpress.com/item/32810890902.html?spm=a2g0o.productlist.0.0.36086231rld53Z&algo_pvid=a7e8ef3c-5d75-4cb5-8c3a-69b1e81165ab&algo_expid=a7e8ef3c-5d75-4cb5-8c3a-69b1e81165ab-0&btsid=3f23964c-71d4-49e3-8f33-7ad1e452f3c7&ws_ab_test=searchweb...
Teacher xilinxacct
Re: First FPGA board
@th3frankxd
This may be just above your budget, but you may want to compare to see what you 'could' get....
https://www.96boards.org/documentation/consumer/ultra96/ultra96-v2/getting-started/
http://zedboard.org/product/ultra96-v2-development-board
I have seen these for $249 USD
I am not affiliated with them (but I do own one)
Hope that Helps
If so, Please mark as solution accepted. Kudos also welcomed. :-)
Scholar u4223374
I'd use the Z-turn but skip the I/O board - it's easy to do a custom PCB that interfaces to the Z-turn's 1.27mm headers directly.
Re adding DRAM: difficult. Most DRAM comes in little BGA packages that are almost impossible to hand-solder, and impedance through the 2.54mm headers is going to be very nasty.
Re clock speeds: the Artix 7 fabric used for all of these boards (the low-end Zynqs are based on the Artix 7) can run at up to about 450MHz. However, getting there will require extremely careful design. 100MHz - 200MHz is a more achievable goal. Most of the boards will have a 33 - 100MHz oscillator, and the FPGA can multiply or divide that clock to get whatever speed you want.
Re JTAG: technically you don't need JTAG for the Z-turn. It'll boot from a microSD card. If you want JTAG anyway (useful for debugging) then I would strongly recomend just using a Digilent HS3. It's more expensive, but still much less than Xilinx's Platfrom Cable USB II, and it's officially supported. The XMOD (from Trenz) also appears to be officially supported.
