Participant canonind
Setting HP Bank Voltage of the ZCU102 for a MIPI CSI2 application
I am using the MIPI_DPHY_DCI I/O Standard on the pins for my application. From table 1-77 of UG571, it is seen that the VCCO voltage needs to be 1.2V. By default the board has 1.8V, so I need to change it.
https://www.xilinx.com/support/answers/66811.html suggests to do it it with the MAXPOWERTOOL002# dongle. Problem is, I don't have it.
So the second option for me is to set it through I2C. Questions at this point:
1) Is it doable through the PS I2C
2) Is it recommended or is it too risky? I don't want do damage the board obviously.
Here is the chain from the schematic:
3) How is the flow to talk to 0x18? I ll talk to 0x75 first to select the 3rd output. But how can I talk to 0x18 afterwards?
Thanks for the help
Re: Setting HP Bank Voltage of the ZCU102 for a MIPI CSI2 application
Ok following the solution posted here, I am able to set the voltage to 1.2 V now.
https://forums.xilinx.com/xlnx/board/crawl_message?board.id=CNFG&message.id=6453
Hi @canonind
Which board you are using? Is it Xilinx proprietary board or Custom Board?
Bhushan
It is the Xilinx ZCU102 Evaluation board.
Community Manager
Community Manager
@canonind Since you are referring to VADJ_FMC rail, I believe you are plugging in an FMC card. Doesn't the FMC card you plugging in have the EEPROM that tells the system controller on ZCU102 to set VADJ_FMC to the required voltage i.e. 1.2V in your case?
If it doesn't, you can set it manually using the System Controller GUI instructions available here . Check the FMC tab
This is the easier method instead of you trying to do the I2C read/write for which you will need to refer to maxim's website for the I2C register set for the MAX15301 (0x18) regulator
- Giri
Just an observation, but the Maxim MAXPOWERTOOL is cheap (or free if you can get a sample) compared to the price of a ZCU-102.
Community Manager
Community Manager
Good Point @bruce_karaffa. Missed mentioning about the Maxim Dongle.
@canonind Since you have the ZCU102, check this AR to get the Maxim Dongle "Free of Charge"
https://www.xilinx.com/support/answers/62629.html
You can set the VADJ_FMC from the SCUI I mentioned earlier as well but do order the Maxim Dongle to use it for later if need be.
- Giri
@gnarahar OK, but how does the FMC assume that I am doing MIPI? Is 1.2V the only applicable I/O Standard for FMC applications?
Following the link you provided, I see that the tool is of version 2017.4 and it asks the Vivado path. I have Vivado 2018.1.
And when I run commands (get some clock freq or blink LEDs), it fails saying that it can not communicate with the board:
[ERROR : Fri, 13, Jul 2018 13:45:03] Error in waitingforoccurance
Traceback (most recent call last):
File "testthread.py", line 245, in waitforoccurance
File "Queue.py", line 176, in get
Empty
[ERROR : Fri, 13, Jul 2018 13:45:03] Timeout reached while waiting for occurance
[ERROR : Fri, 13, Jul 2018 13:45:03] The serial port does not seem to be responding...
Is the board on?
I saw in the AR69640, 2016.4 tools need to be run for my version of the board. Is there a way to download SCUI 2016.4?
Thanks for the link with the free dongle. There appears to be a problem with the MAXIM website.
