Si5324 AC701
I followed the tutorial
https://www.xilinx.com/support/documentation/boards_and_kits/ac701/2014_4/xtp231-ac701-si5324-c-2014-4.pdf
But at the oscilloscope I see the output not a clock but a signal :
Please suggest me, what is going wrong or how should I proceed.
Re: Si5324 AC701
Does it work before you re-program it?
Re: Si5324 AC701
I have no way to know, as without flashing the board the output voltage is zero.
After I flash the hardware with ready to use .tcl file i.e. bit and .elf from Xilinx, I couldn't see the expected clock on the oscilloscope.
Is it possible to check this? and how?
I don't know how to proceed further.
Re: Si5324 AC701
If I take clock wizard, then generate a clock of 100Mhz from clock wizard. Later fed the SMA connector via OBUFDS then I can see a perfect clock. This implies SMA GPIO are working and oscilloscope station is also good.
Re: Si5324 AC701
the tcl script which comes with the xilinx example :
open_hw
connect_hw_server -url localhost:3121
current_hw_target [get_hw_targets */xilinx_tcf/Digilent/*]
set_property PARAM.FREQUENCY 15000000 [get_hw_targets */xilinx_tcf/Digilent/*]
open_hw_target
set_property PROGRAM.FILE {C:/Users/HussainS/Downloads/rdf0229-ac701-si5324-c-2015-1/ac701_si5324/ready_for_download/si5324_bypass.bit} [lindex [get_hw_devices] 0]
current_hw_device [lindex [get_hw_devices] 0]
refresh_hw_device [lindex [get_hw_devices] 0]
program_hw_devices [lindex [get_hw_devices] 0]
disconnect_hw_server localhost:3121
close_hw
In this only see that .bit file is flashed. How does this tcl script take care of flashing .elf file ?
thanks
