Visitor enriqeat2
Two usb serial ports (COM) on ZYBO
I see two COMs on device manager for my ZYBO SoC, this is a problem when I want to connect through SDK because it is supposed to have only one COM. Furthermore I have to say that this happens only on my new laptop which has vivado 2018 installed on it, when using my old laptop with vivado 2014 this is not a problem, I see just one COM.
I can program the bit file, but cannot connect using the SDK. How can I fix this issue?
Visitor enriqeat2
Re: Two usb serial ports (COM) on ZYBO
I contacted FTDI and solved the issue, these are the steps:
1)      Unplug all FTDI-based products.
2)      Run CDM_UninstallerGUI.  Enter only the VID for FTDI (0403) and leave the PID blank.  Here’s a link: http://www.ftdichip.com/Support/Utilities.htm#CDMUninstaller
      Description: Description: cid:image001.png@01CE5D31.A1198CF0
4)      … now click “Add”
      Description: Description: cid:image002.png@01CE5D31.A1198CF0
6)      Click Remove Devices
7)      There should be a notice that the drivers were removed, or if the driver install never completed, you’ll get a notice that there weren’t any drivers to remove – that’s OK.
8)      Reboot
9)      Before plugging in the cable, run the driver installer.  You should “Run as Administrator” – Right click on the downloaded EXE, it’ll be toward the top of the menu selections.
https://www.ftdichip.com/Drivers/CDM/CDM21228_Setup.zip
10)   Now plug in the Zybo device into a USB host port (or hub connected to a USB  host port).  In the device manager, you should see two devices get installed for the unit.  One under the “Universal Serial Bus controllers” tree and one under the “Ports COM and LPT” tree.
Hi enriqeat2,
Can you send us a screenshot of the driver in each computer, like below?
It might also be worth taking a look at Digilent's forum:
https://forum.digilentinc.com/forum/3-digilent-technical-forums/
Andres
Visitor enriqeat2
On my windows 10 Home 2018 64 bit Asus laptop (the one with the problem)
image.pngfirst COMimage.pngsecond COM
On my other laptop: Windows 10 Education 2018 64 bit HP (the one that works normally)
Hi enriqeat2,
I'd try reinstalling the drivers, as explained in this Answer Record:
https://www.xilinx.com/support/answers/59128.html
If that doesn't work, please take a look at this thread from the Digilent forum:
https://forum.digilentinc.com/topic/1092-issue-with-zybo-not-being-recognized-by-hardware-manager-in-vivado-20153-design-edition/
Andres
Visitor enriqeat2
8)      Reboot
Good to hear it's working! Thanks for sharing what worked!
Andres
