VCU118 ES1 parts gone in 2018.1 and 2018.2 release?
Are the VCU118 ES1 parts no longer supported in 2018?
Should I be able to use the non ES1 board file instead? I've been doing so but have found that my data transfers with the MM port will hang sometimes with apparently no interrupt / poll finished in the engine. I've looked at the signals and the read/write transfer seems to be fine at the axi-mm port of the XDMA, and I've tried to with the last two version of the xilinx driver, so I'm not sure what it could be other than the part/board selected. (Guess I should take this to a different board if this is the issue...)
Thanks for the help,
Matt
Advisor evgenis1
Advisor
Re: VCU118 ES1 parts gone in 2018.1 and 2018.2 release?
Hi matt@systemviewinc.com ,
Please take a look at "Vivado 2018.1 missing ES parts" thread [link]. It discusses this exact issue.
Evgeni
Advisor evgenis1
Advisor
Evgeni
Thanks for the link evgensis1, it is what I need to know.
