Visitor oncu
XADC- Vaux7
   I have Z-7020-clg484. I am trying to read the analog signal Vaux7 by using XADC, namely IO_L7N_TI_AD2N and IO_L7P_TI_AD7P trough the pins B15 and C15 which are labeled as FMC-LA30_N and FMC-LA30_P respectively. That corresponds to 35th and 34th pins on FMC.
   My problem is I dont know how to give the input to the FMC LPC?  Should I use sth like
http://avnetexpress.avnet.com/store/em/EMController/Connector-Headers-and-PCB-Receptacles/Samtec-Inc/ASP-134606-01-BLK/_/R-5004319641302/A-5004319641302/An-0?action=part&catalogId=500201&langId=-1&storeId=500201&listIndex=-1&page=1&rank=0
or is there some special cable or adaptor that I can use to give the input?
Thanks in advance, :)
Bests,
Öncü
Scholar pratham
Re: XADC- Vaux7
@oncu No problem
Please check this link
http://www.xilinx.com/products/boards-and-kits/fmc-cards.html#interfaceperipherals
-Pratham
Re: XADC- Vaux7
The FMC-XM105 debug card would allow you to make this connection.
Scholar pratham
Re: XADC- Vaux7
@oncu Refer this UG of XM105 debug card
http://www.xilinx.com/support/documentation/boards_and_kits/ug537.pdf
Check J16 connector on debug card pin no 6 & 8 on page# 20. On these pins you can give inputs
-Pratham
Visitor oncu
Re: XADC- Vaux7
The thing is that as it says in page 8 of the XM105 document, it is supported by spartan 6 and virtex-6 devices. So mine is Z-7030-clg484 Artix device. Is that a problem?
Bests,
Öncü
Scholar pratham
Re: XADC- Vaux7
@oncu No problem
-Pratham
Visitor oncu
Re: XADC- Vaux7
Ok then, thanks :)
