Visitor mdiggitydey
ZC706 Power-Up Issues ~1% of Boards Shipped
I received my ZC706 board and it is behaving in a very strange way. On power-on the fan doesn't turn on and the done LED never lights. Sometimes if the board sits in the on state for a few minutes the fan will turn on and the done LED will illuminate, but that is very rare. Usually switching power SW1 on and off will eventually power the board up correctly, but it is probably close to 1 out of 20 tries when the fan actually comes on and the done LED illuminates. Once this happens The board can be accessed via JTAG, but if not JTAG does not work. I got a paper in the box with the board that ~1% of the ZC706 boards have power-up issues and I tried to follow the link provided to test if my board showed the same symptoms, but the provided test link does not seem to exist. The Provided link was http://www.xilinx.com/kits/zc760power. Has anyone had this issues and if so how did they go about identify the cause? Thanks in advance.
Scholar pratham
Re: ZC706 Power-Up Issues ~1% of Boards Shipped
@mdiggitydey Please go to this link and submit a Service Request
http://www.xilinx.com/support/service-portal.html
Let me know if you cannot login to this link.
-Pratham
Scholar pratham
@mdiggitydey What is the status of LEDs at Power-ON?
Check this AR http://www.xilinx.com/support/answers/54013.html#power
-Pratham
Visitor mdiggitydey
It looks like DS20, DS22, and DS16 are the only ones that are on.
Scholar pratham
@mdiggitydey Is this the first time usage? Can you please open a Service Request with us to investigate this further?
-Pratham
Visitor mdiggitydey
Yes, it is first time usage. I will open a request.
Visitor mdiggitydey
I cannot open a Webcase with my account. Can you at least tell me if this looks like a power up issue or if the board is defective? I will contact the board provider for additional help and start the process of doing an RMA.
Try to reconfigure TI Power module with factory supplied dafulat ZC706 XMl file and check.
The below Answer Records helps to do that
http://www.xilinx.com/support/answers/56811.html
http://www.xilinx.com/support/answers/53599.html
http://www.xilinx.com/support/answers/54022.html
Also refer http://www.xilinx.com/support/answers/60702.html
Visitor mdiggitydey
I don't think this is feasible. I don't have a TI pod to program the power supplies and I am not going to purchase one with the hope that it solves the problem. If it is possible for the power supply circuitry to malfunction to the point of having to reprogram it then maybe the pod should be included. I have a paper that came with the board which says that ~1% of the boards are defective due to power issues and an RMA will be issued on confirmation. How do I prove this? Avnet wants me to open a webcase with Xilinx so that they can confirm the board is DOA before a RMA can be issued and I cannot open a webcase with my current account. What do I do?
Scholar pratham
-Pratham
Visitor mdiggitydey
After closer inspection I realized that I was in the wrong menu. I submitted my request.
Thank you everyone that posted a reply.
