Newbie miguelgg
ZC706: Reading from SD - ADMA problems?
I am trying to read from an SD card inserted in a ZC706 board. In order to achieve that I looked at the files in the FSBL example and I am trying to follow the same steps to mount the SD.
I call the function "disk_initialize" from mmc.c and it runs several commands apparently without problem (the responses are what they are expected to be... Until it arrives at the first ADMA transfer enabled command (CMD55+ACMD51 after CMD7), where it seems to fail returning the status 0x02008001... That 2 over there seems to mean SD_INT_ERR_ADMA, but I don't seem to be able of finding where this error comes from.
If someone could give me some directions on where to look at I would be grateful.
Miguel.
Newbie miguelgg
Re: ZC706: Reading from SD - ADMA problems?
Just solved it.
I'm posting the answer just in case someone runs into a similar issue.
The problem was that I needed to disable the Data Cache and I was not doing it. Simple as that... Silly me.
Newbie miguelgg
Just solved it.
Visitor cjcorrea
Thanks, this worked for me too! To do this, I just add this function call to initialization code:
Xil_DCacheDisable();
and that is from #include "xil_cache.h"
Can anyone provide some info as to why this is necessary (disabling the data-cache)???
