Visitor mengjiuxi
ZCU102 FMC HDMI Input
We know that ZCU102 has 1 HDMI RX connector. However, we need one more HDMI RX connector for our applications. Could I know if this FMC-HDMI card TB-FMCH-HDMI4K can also work on ZCU102. From their website, it says it works fine with KC705.
https://solutions.inrevium.com/products/pdf/TB_FMCH_HDMI4K_HWUserManual_2.03e.pdf
Also, could I also know if there is the difference between the FMC interface on KC705 and ZCU102?
Many thanks.
Re: ZCU102 FMC HDMI Input
Hi @mengjiuxi,
There is a pin count, LPC(low pin count) and HPC(high pin count). Mating LPC to HPC or vice versa, will function, however some of pins will be "no connects".
Visitor mengjiuxi
thanks, Simon,
We are aware of the difference between HPC and LPC, but what we would like to know is that whether the FMC-HDMI board will work on the ZCU102 as it is not listed in the official Xilinx FMC webpage.
https://www.xilinx.com/products/boards-and-kits/fmccards.html#imageprocessing
Without a 100% guarantee, we cannot decide to purchase either the ZCU102 nor the FMC board.
Hi @mengjiuxi,
The site may need an update. From the I/O count and I/O standard, e.g. CML and other differential I/O standard are included in ZCU102. ZCU102 support the FMC board:
http://www.xilinx.com/support/documentation/boards_and_kits/zcu102/ug1182-zcu102-eval-bd.pdf
Hello @mengjiuxi
Have you referred the HDMI PG236 page number 58 and 59.
1_2.JPG15.JPGIf you will see above two images; both of them are almost same.
There shouldn't be a problem for you adding FMC card on ZCU102.
Thank you
The following Answer Record might also help you when assessing whether the FMC card will work with the ZCU102:
Answer Record #68377: https://www.xilinx.com/support/answers/68377.html
