Observer subu.rama
ZCU102 Rev 1.1 Board UI gives error
I have an existing issue with updating the firmware on a ZCU102 Rev 1.1 board as detailed in
https://forums.xilinx.com/t5/Evaluation-Boards/XTP433-running-BIT-exe-from-zcu102-scui-flash-restore-to-update/td-p/1002889
I installed Vivado 2019.1 and repeated the process of updating the firmware. Same issue happens and the firmware does NOT update.
So, I went ahead anyway to see if the next section in XTP433 for running Board UI works.
That also has an issue. The error is a timeout waiting on a "serial port". I am not sure what serial port this is.
See the attached snapshot.
Any help in getting these two issues resolved (updating the firmware and running Board UI) is greatly appreciated. I tried with both J164 jumpered as well as left open.
Subu
image.pngBoard UI set Si5328 freq timeout
Re: ZCU102 Rev 1.1 Board UI gives error
Check out the following AR and let us know if that is your issue.
http://www.xilinx.com/support/answers/68521.htm
,Travis
Observer subu.rama
NO. That did NOT help.
The board is very much on but it now doesn't respond to the @ver command when connected to Interface 3 using tera term until a power cycle!
And I cannot update the firmware because of some errors in the script.
Sigh. It shouldn't be this hard to interface to an eval board and run canned tests.
Subu
Hi @subu.rama ,
I have forwarded the steps of firmware update through EZMove Software to your subu.rama@gmail.com Mail ID. Please follow those steps and share the results. I hope it should get updated to July 5 2017.
Deepak D N
Please Kudo or Accept as a Solution, if it helps.
Observer subu.rama
Thank you, Deepak, but that also failed with the error:  (Also the PS ERR OUT LED came out red after this)
Error: BSL Flashing Failed
Error: Found regular expression in step 2 of test 0 - "(.*)Error(.*)"
Here is the log. I pointed the Vivado path to the 2019.1 version of Vivado.
Board: ZCU102
Serial Number: 0000-0000
Mac Address: 01:02:03:04:05:06
Info: Program MSP Firmware
Version 170705_113233
2017.2 test started...
Info: The test will take 0 hours, 02 minutes, and 16 seconds. 0:02:16
Info: This step started at: 2019-08-01 16:34:00
User has confirmed: "Turn off ZCU102 Board Power.
Connect 2 jumpers across header J164 (parallel with the FMC)
Turn on ZCU102 Board Power"
step finished
Info: This step started at: 2019-08-01 16:34:40
connect -url tcp:127.0.0.1:3121
attempting to launch hw_server
****** Xilinx hw_server v2019.1
  **** Build date : May 24 2019 at 15:13:31
    ** Copyright 1986-2019 Xilinx, Inc. All Rights Reserved.
INFO: hw_server application started
INFO: Use Ctrl-C to exit hw_server application
INFO: To connect to this hw_server instance use url: TCP:127.0.0.1:3121
tcfchan#0
initializing
  0%    0MB   0.0MB/s  ??:?? ETA
  4%    1MB   2.2MB/s  ??:?? ETA
  7%    1MB   1.9MB/s  ??:?? ETA
 10%    2MB   1.8MB/s  ??:?? ETA
 14%    3MB   1.8MB/s  ??:?? ETA
 17%    4MB   1.7MB/s  ??:?? ETA
 21%    5MB   1.7MB/s  00:11 ETA
 24%    6MB   1.7MB/s  00:11 ETA
 28%    7MB   1.7MB/s  00:10 ETA
 31%    7MB   1.7MB/s  00:10 ETA
 34%    8MB   1.7MB/s  00:09 ETA
 38%    9MB   1.7MB/s  00:09 ETA
 41%   10MB   1.7MB/s  00:08 ETA
 45%   11MB   1.7MB/s  00:08 ETA
 48%   12MB   1.7MB/s  00:07 ETA
 51%   13MB   1.7MB/s  00:07 ETA
 55%   14MB   1.7MB/s  00:06 ETA
 59%   15MB   1.7MB/s  00:06 ETA
 62%   15MB   1.7MB/s  00:05 ETA
 66%   16MB   1.7MB/s  00:04 ETA
 70%   17MB   1.7MB/s  00:04 ETA
 73%   18MB   1.7MB/s  00:03 ETA
 77%   19MB   1.7MB/s  00:03 ETA
 81%   20MB   1.7MB/s  00:02 ETA
 84%   21MB   1.7MB/s  00:02 ETA
 88%   22MB   1.7MB/s  00:01 ETA
 92%   23MB   1.7MB/s  00:01 ETA
 96%   24MB   1.7MB/s  00:00 ETA
 99%   25MB   1.7MB/s  00:00 ETA
100%   25MB   1.7MB/s  00:14
Downloading Program -- H:/XilinxDownloads/MSP_Updater (2)/Automatic/tests/ZCU102/tcl/msp_flash/periph_test.elf
	section, .text: 0x00000000 - 0x000142ef
	section, .init: 0x00014300 - 0x00014333
	section, .fini: 0x00014340 - 0x00014373
	section, .note.gnu.build-id: 0x00014374 - 0x00014397
	section, .rodata: 0x00014398 - 0x00014e3f
	section, .data: 0x00014e40 - 0x0001601f
	section, .data1: 0x00016020 - 0x0001603f
	section, .eh_frame: 0x00016040 - 0x00016043
	section, .mmu_tbl0: 0x00017000 - 0x0001700f
	section, .mmu_tbl1: 0x00018000 - 0x00019fff
	section, .mmu_tbl2: 0x0001a000 - 0x0001dfff
	section, .init_array: 0x0001e000 - 0x0001e007
	section, .fini_array: 0x0001e008 - 0x0001e047
	section, .sdata: 0x0001e048 - 0x0001e07f
	section, .bss: 0x0001e080 - 0x0011e2bf
	section, .heap: 0x0011e2c0 - 0x001262bf
	section, .stack: 0x001262c0 - 0x0012f2bf
 86%    0MB   0.2MB/s  ??:?? ETA
100%    0MB   0.2MB/s  00:00
Setting PC to Program Start Address 0x00000000
Successfully downloaded H:/XilinxDownloads/MSP_Updater (2)/Automatic/tests/ZCU102/tcl/msp_flash/periph_test.elf
step finished
Info: This step started at: 2019-08-01 16:35:10
File sent successfully
Info: This step started at: 2019-08-01 16:35:41
Error: Stopped because step 2 failed in test 0
Info: Result for step 0: Pass
Info: Result for step 1: Pass
Info: Result for step 2: Fail
Info: The test took 0 hours, 01 minutes, and 01 seconds. 0:01:01
I ran it a second time also.
Thank you
Subu
Observer subu.rama
This is specific to Deepak's response to try a package he sent me via EZMove.
I tried the same using a Windows 7 laptop with Vivado 2018.2
The program runs successfully but the MSP still is at May 25, 2017 version. It does NOT get updated to July 5, 2017.
A really stubborn MSP, this is.
Board: ZCU102
Info: This step started at: 2019-08-09 12:44:21
step finished
Info: This step started at: 2019-08-09 12:45:42
****** Xilinx hw_server v2018.2
  **** Build date : Jun 14 2018-20:42:52
    ** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
tcfchan#0
initializing
  4%    1MB   2.1MB/s  ??:?? ETA
 14%    3MB   1.7MB/s  ??:?? ETA
 20%    5MB   1.7MB/s  00:11 ETA
 23%    6MB   1.7MB/s  00:11 ETA
 27%    6MB   1.7MB/s  00:10 ETA
 30%    7MB   1.7MB/s  00:10 ETA
 33%    8MB   1.7MB/s  00:10 ETA
 36%    9MB   1.7MB/s  00:09 ETA
 40%   10MB   1.7MB/s  00:09 ETA
 43%   10MB   1.7MB/s  00:08 ETA
 46%   11MB   1.7MB/s  00:08 ETA
 49%   12MB   1.7MB/s  00:07 ETA
 53%   13MB   1.7MB/s  00:07 ETA
 56%   14MB   1.7MB/s  00:06 ETA
 63%   15MB   1.7MB/s  00:05 ETA
 66%   16MB   1.7MB/s  00:05 ETA
 69%   17MB   1.7MB/s  00:04 ETA
 72%   18MB   1.7MB/s  00:04 ETA
 76%   19MB   1.6MB/s  00:03 ETA
 79%   20MB   1.6MB/s  00:03 ETA
 82%   20MB   1.6MB/s  00:02 ETA
 85%   21MB   1.6MB/s  00:02 ETA
 89%   22MB   1.6MB/s  00:01 ETA
 92%   23MB   1.6MB/s  00:01 ETA
 95%   24MB   1.6MB/s  00:00 ETA
 98%   25MB   1.6MB/s  00:00 ETA
100%   25MB   1.6MB/s  00:15
Downloading Program -- C:/zcu102_Xilinx/MSP_Updater (2)/Automatic/tests/ZCU102/tcl/msp_flash/periph_test.elf
 73%    0MB   0.2MB/s  ??:?? ETA
Successfully downloaded C:/zcu102_Xilinx/MSP_Updater (2)/Automatic/tests/ZCU102/tcl/msp_flash/periph_test.elf
step finished
Info: This step started at: 2019-08-09 12:46:08
Info: This step started at: 2019-08-09 12:46:40
Remove the jumpers on J164
Turn on ZCU102 Board Power."
step finished
Info: This step started at: 2019-08-09 12:47:00
step finished
Info: This step started at: 2019-08-09 12:47:01
Writing: '@ver\r'
Info: This step started at: 2019-08-09 12:47:02
@ver
May 17 2017 12:51:57
Writing: '\x1b'
Writing: '\x08'
[('', 'MDB\rEF', '', ''), ('', 'MWB\rF2', '', ''), ('<setmux:0:75:06>', '', '', ''), ('', 'IR0\r18\r01', '', ''), ('', '\x08MWB\rF1', '', ''), ('<setmux:0:75:02>', '', '', ''), ('', 'IR1\r50\r01', '', ''), ('', '\x08MWB\rF0', '', ''), ('', 'IW1\r75\r01', '', ''), ('', 'IR1\r50\r01', '', '')]
Writing: '\t'
:R
Writing: 'MDB\rEF\r\t'
MDB
EF
:P
Writing: 'MWB\rF2\r\t'
MWB
F2
:P
Writing: 'IW0\r75\r06\r\t'
IW0
75
06
:P
Writing: 'IR0\r18\r01\r\t'
IR0
18
01
:P
Writing: '\x08MWB\rF1\r\t'
}:P
MWB
F1
:P
Writing: 'IW0\r75\r02\r\t'
IW0
75
02
:P
Writing: 'IR1\r50\r01\r\t'
IR1
50
01
	Writing: '\x08MWB\rF0\r\t'
:R
MWB
F0
:P
Writing: 'IW1\r75\r01\r\t'
IW1
75
01
:P
'@ver\r\r\nMay 17 2017 12:51:57\r\n>\r\n\x08:R\rMDB\rEF\r:P\rMWB\rF2\r:P\rIW0\r75\r06\r:P\rIR0\r18\r01\r:P\r}:P\rMWB\rF1\r:P\rIW0\r75\r02\r:P\rIR1\r50\r01\r\t:R\rMWB\rF0\r:P\rIW1\r75\r01\r:P\r'IR1
50
01
:P
Info: This step started at: 2019-08-09 12:47:21
Writing: '\x1b'
Writing: '\x08'
[('<setmux:1:74:04>', '', '', ''), ('<readsi570:1:5d>', '', '', ''), ('<calcsi570:1:5d:300:300:00>', '', '', ''), ('<setmux:1:74:00>', '', '', '')]:R
Writing: '\t'
:R
Writing: 'IW1\r74\r04\r\t'
IW1
74
04
:P
Writing: 'IW1\r5d\r8701\r\tIW1\r5d\r07\r\tIR1\r5d\r1\r\tIW1\r5d\r08\r\tIR1\r5d\r1\r\tIW1\r5d\r09\r\tIR1\r5d\r1\r\tIW1\r5d\r0a\r\tIR1\r5d\r1\r\tIW1\r5d\r0b\r\tIR1\r5d\r1\r\tIW1\r5d\r0c\r\tIR1\r5d\r1\r\tIW1\r5d\r8700\r\t'
IW1
5d
8701
:P
IW1
5d
07
:P
IR1
5d
1
:P
A0
IW1
5d
08
:P
IR1
5d
1
:P
42
IW1
5d
09
:P
IR1
5d
1
:P
F4
IW1
5d
0a
:P
IR1
5d
1
:P
0B
IW1
5d
0b
:P
IR1
5d
1
:P
51
IW1
5d
0c
:P
IR1
5d
1
:P
02
IW1
5d
8700
:P
Writing: 'IW1\r5d\r8910\r\tIW1\r5d\r07a0\r\tIW1\r5d\r0840\r\tIW1\r5d\r0900\r\tIW1\r5d\r0a00\r\tIW1\r5d\r0b00\r\tIW1\r5d\r0c00\r\tIC1\r5d\r2\r8900\r8740\r\tMWS\r00\r42a5d3ef79800000\r\t'
IW1
5d
8910
:P
IW1
5d
07a0
:P
IW1
5d
0840
:P
IW1
5d
0900
:P
IW1
5d
0a00
:P
IW1
5d
0b00
:P
IW1
5d
0c00
:P
IC1
5d
2
8900
8740
:P
MWS
00
42a5d3ef79800000
:P
Writing: 'IW1\r74\r00\r\t'
'@ver\r\r\nMay 17 2017 12:51:57\r\n>\r\n\x08:R\rMDB\rEF\r:P\rMWB\rF2\r:P\rIW0\r75\r06\r:P\rIR0\r18\r01\r:P\r}:P\rMWB\rF1\r:P\rIW0\r75\r02\r:P\rIR1\r50\r01\r\t:R\rMWB\rF0\r:P\rIW1\r75\r01\r:P\rIR1\r50\r01\r:P\r\x1b:R\r:R\rIW1\r74\r04\r:P\rIW1\r5d\r8701\r:P\rIW1\r5d\r07\r:P\rIR1\r5d\r1\r:P\rA0\rIW1\r5d\r08\r:P\rIR1\r5d\r1\r:P\r42\rIW1\r5d\r09\r:P\rIR1\r5d\r1\r:P\rF4\rIW1\r5d\r0a\r:P\rIR1\r5d\r1\r:P\r0B\rIW1\r5d\r0b\r:P\rIR1\r5d\r1\r:P\r51\rIW1\r5d\r0c\r:P\rIR1\r5d\r1\r:P\r02\rIW1\r5d\r8700\r:P\rIW1\r5d\r8910\r:P\rIW1\r5d\r07a0\r:P\rIW1\r5d\r0840\r:P\rIW1\r5d\r0900\r:P\rIW1\r5d\r0a00\r:P\rIW1\r5d\r0b00\r:P\rIW1\r5d\r0c00\r:P\rIC1\r5d\r2\r8900\r8740\r:P\rMWS\r00\r42a5d3ef79800000\r:P\r'IW1
74
00
:P
Info: This step started at: 2019-08-09 12:47:32
Writing: '\x1b'
Writing: '\x08'
[('<setmux:1:74:08>', '', '', ''), ('<readsi570:1:5d>', '', '', ''), ('<calcsi570:1:5d:156.25:156.25:01>', '', '', ''), ('<setmux:1:74:00>', '', '', '')]
Writing: '\t'
:R
Writing: 'IW1\r74\r08\r\t'
IW1
74
08
:P
IW1
5d
8701
:P
IW1
5d
07
:P
IR1
5d
1
:P
01
IW1
5d
08
:P
IR1
5d
1
:P
C2
IW1
5d
09
:P
IR1
5d
1
:P
BC
IW1
5d
0a
:P
IR1
5d
1
:P
02
IW1
5d
0b
:P
IR1
5d
1
:P
32
IW1
5d
0c
:P
IR1
5d
1
:P
89
IW1
5d
8700
:P
Writing: 'IW1\r5d\r8910\r\tIW1\r5d\r0701\r\tIW1\r5d\r08c5\r\tIW1\r5d\r0940\r\tIW1\r5d\r0a14\r\tIW1\r5d\r0b1e\r\tIW1\r5d\r0c3c\r\tIC1\r5d\r2\r8900\r8740\r\tMWS\r01\r404dc29a261e7fce\r\t'
IW1
5d
8910
:P
IW1
5d
0701
:P
IW1
5d
08c5
:P
IW1
5d
0940
:P
IW1
5d
0a14
:P
IW1
5d
0b1e
:P
IW1
5d
0c3c
:P
IC1
5d
2
8900
8740
:P
MWS
01
404dc29a261e7fce
:P
'@ver\r\r\nMay 17 2017 12:51:57\r\n>\r\n\x08:R\rMDB\rEF\r:P\rMWB\rF2\r:P\rIW0\r75\r06\r:P\rIR0\r18\r01\r:P\r}:P\rMWB\rF1\r:P\rIW0\r75\r02\r:P\rIR1\r50\r01\r\t:R\rMWB\rF0\r:P\rIW1\r75\r01\r:P\rIR1\r50\r01\r:P\r\x1b:R\r:R\rIW1\r74\r04\r:P\rIW1\r5d\r8701\r:P\rIW1\r5d\r07\r:P\rIR1\r5d\r1\r:P\rA0\rIW1\r5d\r08\r:P\rIR1\r5d\r1\r:P\r42\rIW1\r5d\r09\r:P\rIR1\r5d\r1\r:P\rF4\rIW1\r5d\r0a\r:P\rIR1\r5d\r1\r:P\r0B\rIW1\r5d\r0b\r:P\rIR1\r5d\r1\r:P\r51\rIW1\r5d\r0c\r:P\rIR1\r5d\r1\r:P\r02\rIW1\r5d\r8700\r:P\rIW1\r5d\r8910\r:P\rIW1\r5d\r07a0\r:P\rIW1\r5d\r0840\r:P\rIW1\r5d\r0900\r:P\rIW1\r5d\r0a00\r:P\rIW1\r5d\r0b00\r:P\rIW1\r5d\r0c00\r:P\rIC1\r5d\r2\r8900\r8740\r:P\rMWS\r00\r42a5d3ef79800000\r:P\rIW1\r74\r00\r:P\r\x08:R\rIW1\r74\r08\r:P\rIW1\r5d\r8701\r:P\rIW1\r5d\r07\r:P\rIR1\r5d\r1\r:P\r01\rIW1\r5d\r08\r:P\rIR1\r5d\r1\r:P\rC2\rIW1\r5d\r09\r:P\rIR1\r5d\r1\r:P\rBC\rIW1\r5d\r0a\r:P\rIR1\r5d\r1\r:P\r02\rIW1\r5d\r0b\r:P\rIR1\r5d\r1\r:P\r32\rIW1\r5d\r0c\r:P\rIR1\r5d\r1\r:P\r89\rIW1\r5d\r8700\r:P\rIW1\r5d\r8910\r:P\rIW1\r5d\r0701\r:P\rIW1\r5d\r08c5\r:P\rIW1\r5d\r0940\r:P\rIW1\r5d\r0a14\r:P\rIW1\r5d\r0b1e\r:P\rIW1\r5d\r0c3c\r:P\rIC1\r5d\r2\r8900\r8740\r:P\rMWS\r01\r404dc29a261e7fce\r:P\r'IW1
74
00
:P
Info: This step started at: 2019-08-09 12:47:43
Writing: '\x1b'
Writing: '\x08'
[('', 'MDB\r02', '', ''), ('<savefreq:02:0.0000001>', '', '', '')]
Writing: '\t'
:R
Writing: 'MDB\r02\r\t'
MDB
02
:P
Writing: 'MWS\r02\r3e7ad7f29abcaf48\r\t'
'@ver\r\r\nMay 17 2017 12:51:57\r\n>\r\n\x08:R\rMDB\rEF\r:P\rMWB\rF2\r:P\rIW0\r75\r06\r:P\rIR0\r18\r01\r:P\r}:P\rMWB\rF1\r:P\rIW0\r75\r02\r:P\rIR1\r50\r01\r\t:R\rMWB\rF0\r:P\rIW1\r75\r01\r:P\rIR1\r50\r01\r:P\r\x1b:R\r:R\rIW1\r74\r04\r:P\rIW1\r5d\r8701\r:P\rIW1\r5d\r07\r:P\rIR1\r5d\r1\r:P\rA0\rIW1\r5d\r08\r:P\rIR1\r5d\r1\r:P\r42\rIW1\r5d\r09\r:P\rIR1\r5d\r1\r:P\rF4\rIW1\r5d\r0a\r:P\rIR1\r5d\r1\r:P\r0B\rIW1\r5d\r0b\r:P\rIR1\r5d\r1\r:P\r51\rIW1\r5d\r0c\r:P\rIR1\r5d\r1\r:P\r02\rIW1\r5d\r8700\r:P\rIW1\r5d\r8910\r:P\rIW1\r5d\r07a0\r:P\rIW1\r5d\r0840\r:P\rIW1\r5d\r0900\r:P\rIW1\r5d\r0a00\r:P\rIW1\r5d\r0b00\r:P\rIW1\r5d\r0c00\r:P\rIC1\r5d\r2\r8900\r8740\r:P\rMWS\r00\r42a5d3ef79800000\r:P\rIW1\r74\r00\r:P\r\x08:R\rIW1\r74\r08\r:P\rIW1\r5d\r8701\r:P\rIW1\r5d\r07\r:P\rIR1\r5d\r1\r:P\r01\rIW1\r5d\r08\r:P\rIR1\r5d\r1\r:P\rC2\rIW1\r5d\r09\r:P\rIR1\r5d\r1\r:P\rBC\rIW1\r5d\r0a\r:P\rIR1\r5d\r1\r:P\r02\rIW1\r5d\r0b\r:P\rIR1\r5d\r1\r:P\r32\rIW1\r5d\r0c\r:P\rIR1\r5d\r1\r:P\r89\rIW1\r5d\r8700\r:P\rIW1\r5d\r8910\r:P\rIW1\r5d\r0701\r:P\rIW1\r5d\r08c5\r:P\rIW1\r5d\r0940\r:P\rIW1\r5d\r0a14\r:P\rIW1\r5d\r0b1e\r:P\rIW1\r5d\r0c3c\r:P\rIC1\r5d\r2\r8900\r8740\r:P\rMWS\r01\r404dc29a261e7fce\r:P\rIW1\r74\r00\r:P\r\x08:R\rMDB\r02\r:P\r'MWS
02
3e7ad7f29abcaf48
:P
Info: Result for step 2: Pass
Info: Result for step 3: Pass
Info: Result for step 4: Pass
step finished
Info: Result for step 5: Pass
Info: Result for step 6: Pass
Info: Result for step 7: Pass
Info: Result for step 8: Pass
Info: Result for step 9: Pass
Info: Result for step 10: Pass
Info: The test took 0 hours, 01 minutes, and 48 seconds. 0:01:48
As can be seen in multiple places in the log, @rev produces May 17 2017
step finished
step finished
Writing: '@ver\r'
@ver
 Thank you
Subu
