'1':Configuration data download to FPGA Not successful: DONE did not go high error for Virtex 7
     Am seeing an error like " error cse -'1':errors encountered while programming the device in xilinx "
and in console we seen this
"Programming the fpga by prom failed with error: DONE did not go high"
Please help me in this.
This message simply told Config failed. You need to provide more details about your device/flash and programming operations and procedures and then we can tell what happened.
 I am using an Virtex7 and Flashing it by using Impact 64bit software on Win10 PC, for programming i am using an Xilinx USB Programmer
I have total 6 boards out off that 1 board has this programming issue.
While programming am seeing that 8% is programable and gaves an pop up windows like " error cse -'1':errors encountered while programming the device "
And in Console am seeing thsi error:
Please help me in this regarding.
Sai
 I have total 8 boards out of whixh 3 have the same issues not able to program the xc7V2000T FLASH using Impact 64bit 14.6 tool.
Its flalshing for 8% then suddenly stops nd gave an error on pop window as "error cse -'1':errors encountered while programming the device in xilinx"
After program failed ,on Console seeing the below message:::
Reset Core
Using x16 mode ...
Set Data Width
'1': Erasing device...
done.
'1': Erasure completed successfully.
Reset Core
Using x16 mode ...
Set Data Width
INFO:Cse - Using Buffered Programming.
'1': Programming Flash.
INFO:Cse - Core Status Register: [80] : 0
INFO:Cse - Core Status Register: [81] : 0
INFO:Cse - Core Status Register: [82] : 0
INFO:Cse - Core Status Register: [83] : 0
INFO:Cse - Core Status Register: [84] : 1
INFO:Cse - Core Status Register: [85] : 0
INFO:Cse - Core Status Register: [86] : 0
INFO:Cse - Core Status Register: [87] : 1
INFO:Cse - Core Status Register: [88] : 1
INFO:Cse - Core Status Register: [89] : 0
INFO:Cse - Core Status Register: [90] : 0
INFO:Cse - Core Status Register: [91] : 0
INFO:Cse - Core Status Register: [92] : 0
INFO:Cse - Core Status Register: [93] : 0
INFO:Cse - Core Status Register: [94] : 0
INFO:Cse - Core Status Register: [95] : 0
'1': Errors encountered while loading microprogram.
ERROR:Cse - '1': Errors encountered while programming device.
Reset Core
PROGRESS_END - End Operation.
Elapsed time = 412 sec.
'1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and mode settings.
SaiPraveen
