fuxx_14
Artix7 CRC configuration register content
When I read CRC configuration register (address 0x0) via ICAPE2 primitive, I always get back 0x0.
Since reading of other registers returns plausible data, there has to be a specific problem with CRC register.
Which settings do I need to get this data filled with CRC of bitstream?
Currently I use:
set_property POST_CRC ENABLE [current_design]
set_property POST_CRC_FREQ 50 [current_design]
set_property POST_CRC_SOURCE PRE_COMPUTED [current_design]
set_property POST_CRC_ACTION HALT [current_design]
set_property POST_CRC_INIT_FLAG DISABLE [current_design]
kkn
can you set the following in case you have not set
set_property  BITSTREAM.GENERAL.CRC ENABLE [current_design]
fuxx_14
Thanks, but CRC had already been enabled.
Therefore it has to be another setting or the CRC configuration register read content depends on other register contents, for instance FAR.
iguo
CRC reg has no direct relationship with POST_CRC function. Please read ug470 to understand what RBCRC is. CRC reg is used to store the CRC-32 value during bit downloading.
Ivy
