UdayanMallik
@E Simulation failed: SIGSEGV.
I am compiling my HLS testbench to simulate a simple multiplier.
I am receiving the error described in the title.
Does anyone know of a quick solution to the problem?
Test Bed.
.h file for program in Vivado HLS to multiply two floating
point numbers
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <math.h>
#include "FloatingMultiplication.h"
int main () {
// Number of Samples in the input file - Forcing File
int SAMPLES=5;
// File to print computed data
FILE *fp;
// File to read input data
FILE *fr;
// Variable to read input data
char tp[32];
data_t output;
// Open output File
fp=fopen("out.dat","w");
float a;
// Open input file
fr=fopen("squareArrayIn.dat",'r');
for (int i=0;i<=SAMPLES;i++) {
// Scan input file for input to the Simulation
fscanf(fr, "%s",tp);
// Convert the string to a floating point number
a = atof(tp);
// Compute
FloatingMultiplication(&output,a);
fprintf(fp,"%f\n", output);
fclose(fr);
fclose(fp);
// Lets compare the numbers
printf ("Comparing against output data \n");
if (system("diff -w out.dat squareArrayOUT.gold.dat")) {
fprintf(stdout, "*******************************************\n");
fprintf(stdout, "FAIL: Output DOES NOT match the golden output\n");
return 1;
} else {
fprintf(stdout, "PASS: The output matches the golden output!\n");
return 0;
The Device under Test is:
void FloatingMultiplication (data_t* b, data_t a)
*b = a * a;
point numbers
#ifndef FLOATINGMULTIPLICATION_H_
#define FLOATINGMULTIPLICATION_H_
typedef float data_t;
void FloatingMultiplication (data_t* b, data_t a);
#endif
