Easier way to flash bitstream to QSPI on ZYNQ-7000
Hi, All
I am using ZYNQ-7000 PL only with my design. And I am not going to use the PS. I just want to burn my bitstream to the QSPI flash with connect to ZYNQ-7000.
After Google for a while, I found that I need to build a BOOT.bin which is called FSBL, However FSBL need a hdf to do this. and hdf need the deisgn build with block design.
My design this all verilog or xci, it there any way easier to burn bitstream just like Artix series FPGA?
@jimmystone No without creating fsbl i think you can't able to do it.
you need to create block design with zynq7000 ip and then in sdk you need to create boot.bin .
I have done the same thing.
Hi, richa1989
Thanks for reply. How do you configure the paratmeters in zynq-7000?
With all default?
@jimmystone  In peripheral io pins select quad spi which you are using.In ps-pl configuration remove the tick on M axi GP0 interface.In my project I dint use DDR.
Others are configured as default.
