rajkumar_xilinx
Error: cannot write hardware definition file as there are no generated ipi blocks
dpaul24
@rajkumar_xilinx ,
There is nothing for SDK to do here.
What do you want to do in SDK? What is your intention?
This is just a simple port to port assignment RTL code! If you are not using any of the uP cores, then SDK is of no use.
Please read the related tutorials and documents.
https://www.xilinx.com/products/design-tools/embedded-software/sdk.html
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
dpaul24
@rajkumar_xilinx ,
