cois
Failed to query common flash interface.
Hi All,
This is rather urgent.
I have Programmed this same flash on this same PCB many times before. I got this Message today and nothing that I do, with the help from existing answers on the forum, solved the problem. I am using ISE 13.1 with a XC6VLX550T and a PC28f256P30BF Parallel Flash. The speed on my cable is 3MHz
How do I fix this.
INFO:iMPACT - Current time: 2015/05/27 09:24:58 AM
PROGRESS_START - Starting Operation.
Maximum TCK operating frequency for this device chain: 10000000.
Validating chain...
Boundary-scan chain validated successfully.
1: Device Temperature: Current Reading:   37.09 C, Min. Reading:   35.61 C, Max. Reading:   37.09 C
1: VCCINT Supply: Current Reading:   0.955 V, Min. Reading:   0.952 V, Max. Reading:   0.970 V
1: VCCAUX Supply: Current Reading:   2.470 V, Min. Reading:   2.470 V, Max. Reading:   2.473 V
Cable speed is default to 3Mhz or lower for BPI operations.
Current cable speed is set to 3.000 Mhz.
Setting Flash Control Pins ...
Populating BPI common flash interface ...
INFO:iMPACT - Core Status Register: [80] : 0
INFO:iMPACT - Core Status Register: [81] : 1
INFO:iMPACT - Core Status Register: [82] : 0
INFO:iMPACT - Core Status Register: [83] : 1
INFO:iMPACT - Core Status Register: [84] : 1
INFO:iMPACT - Core Status Register: [85] : 0
INFO:iMPACT - Core Status Register: [86] : 0
INFO:iMPACT - Core Status Register: [87] : 0
INFO:iMPACT - Core Status Register: [88] : 1
INFO:iMPACT - Core Status Register: [89] : 0
INFO:iMPACT - Core Status Register: [90] : 1
INFO:iMPACT - Core Status Register: [91] : 0
INFO:iMPACT - Core Status Register: [92] : 1
INFO:iMPACT - Core Status Register: [93] : 0
INFO:iMPACT - Core Status Register: [94] : 0
INFO:iMPACT - Core Status Register: [95] : 0
'1': Errors encountered while loading microprogram.
INFO:iMPACT - Failed to query common flash interface.
PROGRESS_END - End Operation.
Elapsed time =      2 sec.
Thanks in advance.
kkn
can you try to use 14.7 impact and see if this programmer tool is able to program
http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools.html
--Krishna
madhavij
Hiii,
I am Using same Version 14.7 ISE tool for my program,but still i am unable to program my Virtex 7 PROM in impact.
i am also try for lower versions also,but no use at all.all my other boards are working with same code,but only one board was unable to program V7 PROM.
all my hardware setting are same as per datasheet,but still i am getting same error.FPGA was programed successfully,but PROM was not.
can anyone resolve this issue,please inform us to program the V7 PROM(PC28F512P30B)
vrinda
diego.diaz.m
I have a similar problem, it looks like the flash suddenly stops working. I'm able to load the flash sometimes but when it fails shows this:
INFO:iMPACT - Downloading core file C:/Xilinx/14.7/LabTools/LabTools/virtex5/data/xc5vsx95t_jbpi.cor.
'8': Downloading core...
 Match_cycle = NoWait.
Match cycle: NoWait
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0011 1111 0101 1110 0000 1011 1100 0000
INFO:iMPACT:2492 - '8': Completed downloading core to device.
INFO:iMPACT - Core Status Register: [80] : 1
INFO:iMPACT - Core Status Register: [83] : 0
INFO:iMPACT - Core Status Register: [84] : 0
INFO:iMPACT - Core Status Register: [88] : 0
INFO:iMPACT - Core Status Register: [90] : 0
INFO:iMPACT - Core Status Register: [92] : 0
'8': Errors encountered while loading microprogram.
I can't probe any of the data or address lines due to the PCB design, so I'll get the flash replaced, but I'd like to know what are the errors in the core status register in case the problem is other than a bad flash.
Diego
cois
Hi Diego,
I could not, till today, resolve this problem. I had a very knowledgeable engineer, that do training in Africa on Xilinx products, from an engineering company in Sandton South Africa, have a look at this problem. He came to the conclusion, after looking at my design, error messages, log files and e-mails between me and Xilinx Support, that the problem is not the Flash but indeed the Xilinx FPGA. He told me that there is a workaround. We are working on that.
Cois
diego.diaz.m
Hi Cois,
Thanks, I'll contact the Xilinx representative that supports the company, it did look strange to me a new board with flash failure, although is even more so issues with the FPGA.
Diego
