Visitor mike65535
Finding the bitstream (.bit) file
When I go to program my device, (for the .bit file) Vivado always defaults to looking in some obscure directory, rather than the one in which I am working.
The file Vivado wants to use:   /home/myname/tools/Xilinx/Vivado/2018.3/data/xicom/cfgmem/spi_xc7k160t_pullnone.bit
The file that's correct:  /home/myname/dev/devHDL/S_Interface/S_Interface-k7-V03.runs/impl_1/S_InterfaceV03.bit
How can I get Vivado to automatically look in the place in which it put the bitstream?
Visitor mike65535
Re: Finding the bitstream (.bit) file
Vivado is looking in a place in which it is not even writing a file.  This is a bug IMO.
Hi @mike65535 ,
Are you opening the HW Manager within a Vivado project? If so, it should default to look into the project directory.
Otherwise, if you are just opening the HW Manager without having a project open, it will default to look into some Vivado Tools directory.
Andre Guerrero
Product Applications Engineer
Visitor mike65535
I am opening HW Manager from within a project.
This is a project I inherited. I don't know its original folder structure.
you might see this if you have programmed the flash attached to the fpga.
The bit file it is pointing is indirect programming logic bit file which will be required for programming the flash
Visitor mike65535
Is there not a setting I can look at and hopefully modify, telling Vivadi where to look?
As I wrote, Vivado puts the bit file there every time I build, yet it doesn't know to look there?
Visitor mike65535
Anyone?
Hi @mike65535 ,
Thers is no such seetings to tell the Vivado to search for BitStream file.
If you build a project and then program the FPGA it will correctly point out the Bit file. Otherwise we have to manually give the path.
Hope you understand.
Deepak D N
Please reply or give kudo or Mark it as an Accepted Solution.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Visitor mike65535
Observer chris1220
I also have this issue, however, there are some rare cases (projects, computers, ?) where it properly preloads the bitstream file box with the one used previously.
Hardware manager is always opened from the Flow Navigator -> Program and Debug.  Programming is initiated by right clicking on xc7a35t_0.  I would like to know what sequence needs to be done so that the previous file is placed there instead of the C:/Xilinx/Vivado/2019.1/data/xicom/cfgmem/spi_xc7a35t_pullnone.bit file.
Incidentally, if I have a debug core built into the project, the correct default .ltx file is listed.
