Visitor snitamai
How to generate encrypted / unencrypted bit file
How can I generate two types of bit files, encrypted and unencrypted, from a single implementation data?
回复: How to generate encrypted / unencrypted bit file
Unencrypted:
Just directly run write_bitstream based on the opended implementation result:
write_bitstream xxx.bit.
Encrypted:
Refer to Xapp1239 or Xapp1267:
https://www.xilinx.com/support/documentation/application_notes/xapp1267-encryp-efuse-program.pdf
Briefly, set a bunch of properties before you run the write_bitstream command in the Tcl console. Don't save these to the design, and you will always get a 'clean' dcp file.
Unencrypted:
Encrypted:
Visitor snitamai
Thank you for your reply.   It is solved.
After changing the setting in "Edit Device Properties", "Generate Bitstream" was executed from "Flow Navigator".
The modified bitstream was created by running from "Tcl Console".
