03-22-2018 08:07 PM - edited 03-22-2018 08:30 PM
Hi Expert,
which aspect should be consider, if I want to select a compatible flash for FPGA?
I have referenced the following reference,but the flash which I select is not in this list.(The flash I select is MT25Q,and FPGA is Spartan-6).
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/pim_r_supported_spi_bpi_proms.htm
What I want to know is that:
If I want to select a flash,what I know to consider is :
1:Capacity:
1)The bitstream size of the FPGA device can be load into the falsh
2)If MultiBoot , need more larger
2:Interface:
1)If I use SPI X1, the flash need to support SPI X1 mode
2)Flash CMD need compatible with FPGA configuration opcode(like 0x03 and 0xe8), as the attachment show.
3:Impact need support this Device, or need to change the environment variable .
https://forums.xilinx.com/t5/Configuration/V6-LX240T-SPI-flash-N25Q256-Problem/td-p/646977
Are there other aspect need to consider?
03-22-2018 10:27 PM - edited 03-22-2018 10:29 PM
you can use the MT25Q flash, check the following AR how to program this flash
https://www.xilinx.com/support/answers/68677.html
if you are going to use multiboot then try to use the flash part which can hold the number of bitstreams you will be programming
03-22-2018 11:02 PM
@kkn Thanks for solving my problem.
But if MT25Q is supported by iMpact, why not update the following information? This may convenience for us to reference.
03-22-2018 11:30 PM
Impact tool is matured tool and there are no change requests for this tool/doc. so this is the reason there is a solution record.
