alex2301
IDELAYCTRL problem
Good day. An error occurs during implementation. I use UG953 to add IDELAYCTRL but don't understand how to make the port map?
[DRC PLIDC-10] IDELAYCTRL missing for IODELAYs: There are 1 IDELAY/ODELAY/IODELAY cells in the design which requires IDelayCtrl, but there is no IDelayCtrl cell
Used xc7z020clg400-1.
Tags (2)
pthakare
Hi @alex2301
I dont see IDELAYCTRL instantiation in VHD file you shared.
You have instantiated IDELAY and ISERDES but IDELAYCTRL is missing . Refer UG471 for details around IDELAYCTRL
pthakare
Hi @alex2301
alex2301
I added IDELAYCTRL
IDELAYCTRL_inst : IDELAYCTRL
port map (
--RDY => open, -- 1-bit output: Ready output
REFCLK => clockADC, -- 1-bit input: Reference clock input
RST => resetn -- 1-bit input: Active high reset input
and changed IDELAYE2
DELAY_src=> "IDATAIN"
and this solved the problem.
