Observer jsy524
ISE 14.7 cable connection problem
Hello.
I have trouble with my cable.
I have xilinx platform cable USB(DLC9G) and use xilinx ISE 14.7 virtual box version in 64 bit Windows 10.
In ISE 14.7, I failed to connect my cable.
So I installed ISE 14.6 to connect that.
However when I tried to open 14.6 64 bit ISE, it failed to open.
I can open 32 bit version but cable is not connected since it works on 64 bit version.
Please let me know how to connect my cable on 14.7 or how to open 64 bit 14.6 ISE.
Thank you.
回复: ISE 14.7 cable connection problem
Hi j,
14.6 ISE is not supported on Windows 10.
You can check the section 'USB Pass-Through for Unrecognized Programming Cables' in https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug1227-spartan6-vm-windows10.pdf to see if you can make the USB cable recognized on Win10 with 14.7 VM version.
Ivy
Observer jsy524
Hello.
I am so sorry for my late response.
I followed your advice and checked that my cable is connected well.
However, when I activate impact program, it fails to recognize my cpld.
Impact shows that my chips are unknown (so bypass).
Furthermore, I think it recognizes my chips as FPGA chips since only bit files are available when I double click them.
Please help me to solve it.
Thank you.
