luhb
JTAG: Xilinx USB Cable vs. Regular Cable
Hi dear Xilinx community,
What is the difference between programming the FPGA via Xilinx USB cable or regular USB cable?
Background info: I try to run the helloworld example program for my Mini-ITX-7Z-ASY-G (7z045 SoC), but after programming when I try to run the code example, the cores get suspended. The example works for my ZC702, so i tried to spot the differences. The Mini-ITX has a JTAG connector J1 (for Xilinx Cables I guess?) and additionally the regular micro-USB connector (U3), which I also used on my ZC702 eva board.
I also wonder why writing the bitstream to the Mini-ITX via JTAG takes so long. When I remember correctly, programming the Artix-7 on ZC702 took like 1-3 seconds or so (Bit file size ~5MB), programming the same basic example for 7z045 takes half a minute (~11MB, write speed only 0.7MB/s - 1.2MB/s)
Is it possible that I have to use the Xilinx USB cable? I already tried re-installing Xilinx Cable Drivers, but this didn't change anything
Have a nice week!
Ubuntu 18.04 LTS - 64 Bit
Xilinx Vivado 2018.2 - 64 Bit
hj
From cable standpoint I can share some details. Xilinx cable has max frequency of 12 Mhz and default is 6 Mhz. Whereas Digilent USB cable has default of 15 Mhz. So there is a JTAG frequency difference.
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
hj
luhb
I also did some research on this, and this was also the only real difference I found. The Xilinx Cable Platform also can be used as SPI or serial, but the regular USB cable offers all JTAG functionality regarding programming the FPGA and running your user programs.
