MASTER SPI's config pin can connect direct to VCC_3.3v?
Can I delete R50 ,connect M0_0 direct to VCC_3.3V
Mentor
Mentor
Re: MASTER SPI's config pin can connect direct to VCC_3.3v?
yes, it should be fine.  Resistors like that are sometimes used for debugging a board, by lifting the resistor and changing the input voltage.   But if you don't need any debugging..   go ahead and delete it.
Mentor
Mentor
