MicroBlaze - UART
Hello
I should use from JTAG console in MicroBlaze debug module.
I defined Ext_JTAG_RDCK and Ext_JTAG_RESET ports in the debug module.
but I don't know how to connect them to MB and test the project?
I should test the interrupt in the project.
I defined the interrupt module and connected it to interrupt input port in MB.
please guide me
You should use the use the uartlite IP, connect it to your interconnect IP and that's it.
Thanks for your answer
to which MB port should I connect JTAG console of debug module?
is there documentation with more detail that I can read it?
MB debug module includes a UART with a configurable slave bus interface which can be configured for either AXI4_Lite interconnect or PLBv64 bus. UART TX and RX signals are transmitted over FPGA JTAG to and from MB debug.
I think not to need UART_Lite core.
is it true?
