shifali15
Minimum CCLK frequency for ARTIX-7
I am using XC7A50T in my design. I have to configure ARTIX-7 in slave select map mode. What should be the minimum CCLK requirement. I have referred xapp583 and ds181 documents. Minimum CCLK frequency is not mentioned.
Thanks in advance.
@shifali15
The minimum frequency for CCLK in a 7-Series device is 3MHz.  See BITSTREAM.CONFIG. CONFIGRATE in Table 36 of UG908(v2020.1).
Cheers, Mark
