08-28-2017 08:10 AM
Hi all,
I recently got a Nexys4 DDR board. When I tried to test it, there seemed to be no target detected:
I tried to reinstall the usb-jtag driver by following the solution:
https://www.xilinx.com/support/answers/59128.html
But didn't work. My vivado version is 2017.2.
Can anyone who worked with this device before offer any advice?
Thanks a lot.
08-29-2017 04:26 AM - edited 08-29-2017 04:26 AM
Thanks for the reply.
I am using Windows 8.1. I had tried to reinstall the driver before I posted this topic but it didn't work.
This morning I figured out that the simplest solution was to install Vivado 2015.1 and the diligent board worked well. For Vivado 2014.2 and 2017.2, it didn't. I will try later by installing the windriver then.
Best
08-28-2017 08:31 AM
Hey @conanandai100,
If I remember correctly, the Digilent boards require the Digilent Adept drivers to be properly recognized.
Maybe this helps,
Herbert
08-28-2017 08:40 AM
Hi Herbert,
Thanks for your quick reply.
Yes, I used to have a Nexys2, which worked well with digilent adept. But this Nexys4 DDR didn't, with a "No Device Connected" in the GUI. That's why I am a little bit confused now.
I checked the jumper of JP1 also, which is on the JTAG mode.
08-28-2017 08:52 AM - edited 08-28-2017 09:09 AM
Hey @conanandai100,
You're wecome!
Depending on the operating system there can be problems with access rights and usb device configurations.
Last time I used it, the djtgcfg tool was very helpful in narrowing down the problem.
Hope this helps,
Herbert
08-29-2017 02:45 AM
Hello @conanandai100,
Can you please confirm on which OS you are working on ?
Please follow below answer record to reinstall drivers:
https://www.xilinx.com/support/answers/54382.html
also reinstall windrivers if you are working on windows OS:
https://www.jungo.com/st/products/windriver/
Thank you.
Best
