gastonmelo1980
PWM microblaze
Hi to all,
               Im suing microblaze on spartan-6 and I create a PWM using XTmrCtr in count_down mode. Now I want to change the PWM duty cycle. Looking the xps_timer_0 it show the PWM in the module, but in SDK XTmrCtr.h there is no mention to PWM.  The max PWM freq I was able to implement was 148Khz.
1) is it possible to create Mhz PWM with the timer?
2) how can I change the dty cycle of the pwm?
is there an example reference or link I could read about?
thanks for your help.
Gastón
