krn-krn
Pprogramming FPGA
1.We are trying to program our custom board (XC7Z014clg484 -2) , once we connect the hardware, JTAG detects a hardware device of speed -1(i.eXC7Z014clg484 -1) which is not our custom board, eventhough we choose the correct custom board part number .
2. Later, If we program the device, it shows error like "  program_hw_devices' failed due to earlier errors "  , we checked all the components regarding Fpga its getting proper voltage, we even tried changing cables.
3.We created a code with  speed -1(i.e XC7Z014clg484 ), where the JTAG detected hardware with speed -1 ,we dumped it worked first time but when we reprogram 3-4 times it failed with above mentioned error.
krn-krn
We replaced zynq ic it's working fine now, Thank you.
fernandovives
Check if you have a correct read from the XADC( i.e. the temperature value of the FPGA). This issue happens to me. Was a problem in the PCB layout of the board.
If you have another board , check if you have the same issue.
When ever you get 'failed due to earlier errors' error, the better approach is to redesign your whole project.
joancab
Advisor
Advisor
Is the part traceable?
krn-krn
