Problem with cable connectivity with Spartan 3E - 1200E
I am using a Nexys 2 Diligent Board- Spartan 3E 1200E and working on Xilinx version 14.7 ISE.
I am facing issues while initializing the chain or getting Auto connect to cable. Earlier it was working perfectly fine, now there seems to be an issue with it.
I am a Windows 10 user. Any help regarding this would be very much appreciated.
Attaching : Screenshots of the errors/warnings/logs.
I never work with a VM version .. Was the same cable working with same board and same computer?
Two possible reasons:
1. the cable driver got broken. Generally re-install cable driver would help but for this VM version, the cable driver is pre-installed.
2. HW connection issue. Please double check the Jtag chain connections - board tdi-> cable tdi->device tdi-> device tdo-> board tdo. See if there is some issue.
If you have another cable, you can have a test first to see which part is wrong.
